Should be identical. I'm not aware of any changes but you could always contact Wavetrac directly and ask.Hello I saw wavetrack lsd for w124 is still available in their site. but I have a question is that the same product as you guys bought it in 2014-15 or is it different?
Same thing. No changes.Should be identical. I'm not aware of any changes but you could always contact Wavetrac directly and ask.
I thought it was a limited production run for the group buy and shortly thereafter, but I guess I was mistaken. Interesting and good to know.
Only thing I will add/counter to dave is I think a LSD is an Awesome mod...esp on the street!
Couple our Early ASR w/ a proper LSD and it no longer becomes a total kill joy...esp if you're trying to get the jump/make a quick u-turn or anything else that involves turning and the gas pedal @ more then 1/2 way.
I also find the cars more stable when driving spiritedly up/around/through the twisties...and should things get a little over the top ASR actually cuts in @ moments that make Sense once both wheels are being driven... If things Really get out of hand, I find how the car responds to my inputs to correct far more natural w/ an LSD. Open diff's do strange things when going sideways...@ least strange in my mind.
Anywho, i've said it before but quantifying an LSD in an 036 is one of the harder things to do verbally but hop back and forth from one w/ LSD vs not, go for a run down your fav road and you'll be Sold...
If you have a car WITHOUT ASR... by all means, you need a limited-slip diff! It's a YUGE difference compared to a peg-leg open diff.
Labor to install is somewhere in the range of 6-10 hours total, including pulling the diff out of the car, taking it apart, installing the LSD, checking backlash & preload, praying it doesn't need to have the shims adjusted, then re-installing everything. This is advanced DIY and other than a few photos on my website, the main reference is the FSM (from the 126 chassis) which walks you through the process. If you don't have access to precision dial gauges and have the ability fabricate some tools as needed, you'll be far better off paying someone that has done this before. If you screw it up, it's an expensive lesson.
It's been years since I've done this, but IIRC pulling the pumpkin out of the car wasn't too bad, 1-2 hours if all the fasteners cooperate... another 1-2 for installation. Strip any bolt heads or break stuff, and uh-oh.It's 14+ hours per MB to R&R and Build the diff.
I'd split that time about in 1/2 for each part of the job.
WaveTrac should supply the spring clips needs to retain the axle stub shafts, but I guess we'll find out when we receive them.
You'll need to buy other stuff separately... I'd replace the differential side oil seals, O-rings for the side bearing carriers, and the ASR sensor O-rings too. Oh, you'll need to buy the bearings too... part numbers shown here, click the "bearing" pics. We'll need to have Gerry create one of his signature "HOW TO" threads for the LSD install.
NOTE: There is an EPC error on the ASR sensor O-rings... EPC only shows the thick O-ring for plastic ASR sensors, it should also show the thin O-ring for metal sensors. Every 036 that I've touched has the metal sensors, which requires O-ring 014-997-97-48 (not shown in EPC).
If you DIY the job, you'll see why they charge what they do. $700 isn't cheap for an LSD install, but it's not outrageous either. If the $700 includes fiddling with the pinion too, just pay the man.I hate to be a cheapskate as it is clear Matt knows what he is doing, but dropping 2k on a diff rebuild wasn't really something had planned for right now. I keep thinking a diff rebuild should be cheaper than that, even with 1250 plus bearings and seals in parts. $700 in labor when the diff is already out? Seems steep.
Of the 13 shim thicknesses originally available, only 6 were still available a few years ago; the rest are NLA. I don't know current status. MB expects you to use a thicker shim and have it machined down as needed. To get the numbers exactly in spec, you often need increments of 0.05mm. Meaning that (for example) a 1.70 may be too much, 1.60 is too little, and 1.65 would be just right. And MB only has 1.60 and 1.80 available, so you need to buy a 1.80 (or use that 1.70 you just tried) and machine it. Fun stuff.I think 700$ is a good price. Given the tools and experience you need to do the job professionally. I had to change the shims on my diff during the Wavetrac install. Luckily I had several shims in my parts bin. Quite some are NLA for now but a specialized shop might have some in the parts bin too.
If you DIY the job, you'll see why they charge what they do. $700 isn't cheap for an LSD install, but it's not outrageous either. If the $700 includes fiddling with the pinion too, just pay the man.![]()
Just make sure the rear-end shop has done Mercedes diffs, and is familiar with the shims. If not... don't let them touch it.I kind of get it, but I would think any decent shop is going to have or be able to fabricate any type of shim required. I am happy to pay for good work but in reality I don't have any way to get the diff to Leistung this week and I am trying to get this job done. Metric, Sun Valley etc are all within about 20 min of my house. I'm guessing there is a rear end shop closer to me that can handle this.
Yah you may be right about that. If I had thought about it I would have dropped it there when I scooped up the subframe from him.If I were you I would find the time to get it to Matt. Don’t mess around trying to save a $.
Think “Pay me now or pay me later”
I already have the fsm so will just follow that.Is there a write up on this install anywhere? Or a parts list?
Sent from my SM-G955U using Tapatalk
Too small for what? The axle stub shaft splines are the same regardless of differential type. They are single-use, the clip will become distorted during installation/removal and should be replaced each time.
You pull real hard.Ok so clearly there is no way to get the stock clips back on with the diff in the case. So I'm guessing these other clips go down the bore and lock into the diff with spring pressure. That all seems doable.
But how do you remove the clips to get the axle stubs back out if you need to?
So far this job is not that big a deal. But I am not messing with the pinion.
I figured as much.You pull real hard.
Make sure your mesh pattern is Correct ..just because your not touching the pinion doesn't mean your diff hasn't opened up and require re-shimming.
Jono
Sent from my SM-G960U using Tapatalk
Whaaa....? Which gear ratios is it "opened up to" and which ratios require spacers? I hope they are just adding spacers for 3.27 / 3.69 applications. There should be a completely different unit (with different dimensions) for 2.24/2.47 gears. I really hope they didn't screw it up.
Again: Whaa...? There is no need to touch the pinion or crush sleeve to install the WaveTrac! You don't need to remove the pinion unless changing gear ratios, which is always a bad idea - buy a diff with the ratio you want. The link below is an article from Stu Ritter which explains in detail why it's a Very Bad Idea to mess with the pinion, unless you have all the special tools, and word on the playground is that only a handful of shops in the USA have the tools to do this properly:
http://www.w124performance.com/docs/mb/other/differential_info_Stu.txt
IMO, the bigger nuisance for WaveTrac (or Quaife, or factory LSD) installation is that many of the shim thicknesses are NLA, and if you want to get the bearing preload and gear backlash exactly in spec, you may need to buy thicker shims and have them ground down in 0.05mm increments as needed. And even when you have a proper shim assortment, it's a lot of trial & error assembly. I've built something like 6 or 7 of these so I'm quite familiar with the process. It's not difficult, just time consuming.
Side note: This may not be widely known, but I was the one who worked with WaveTrac back in 2013 to have them develop the diff for the 500E application. They wanted to build one that required custom machining of the factory axle stub flanges, and I had to convince them this was a terrible idea and nobody would buy one if they did that. It was a lot of time and effort, I had to send them multiple diffs for R&D, all at my cost out of pocket. I was supposed to get a free WaveTrac diff for my efforts and I never did get that, which still pisses me off. (They made a pile of money off selling dozens of these, not even a thank you?) As a bonus, they never returned the flanges I send them for R&D so now I also have a 500E diff collecting dust that is useless without the flanges. I like their product but I am not impressed with their customer service. </rant>
So, I took a few days off and went back home. Finally got time to assemble the 2.65 diff with all new bearings and the wavetrac lsd. I was lucky to have some spare adjustment spacers for the side covers, many sizes not available anymore! Got the pinion gear pre load, pinion to Crown wheel play and housing pre loading nicely dialed in after changing spacers a few times. Filled it with Castrol 75W140. If I have time during the upcoming weekend I even might install it.
If the existing diff is OK - no gear whine on/off throttle, no excess play or wear, etc... it is DIY'able. However you will need dial gauges / micrometers, and you may need to fabricate some tools, as seen in my photos here.Dave- are you saying above that you have DIY'd the installation of these Wavetrac LSD's without special MB equipment? It is something I would rather do myself if I can. My 500E diff is not making noise or anything at all - "just" that there is noticeable play in the gears or internal components.
I measured the backlash and bearing preload of the old/existing setup before taking it apart, then used that as a guide when installing the new diff. The bearing preload was generally low (near zero) on the old stuff, and I usually had to dink with different shims to get things back into factory spec. Backlash was almost always within spec on the old/worn diff.Could I for example, clean everything - inspect for obvious wear or damage and if good fit the Wavetrac and check the feel of the diff and maybe use engineer's blue to see how the gears are meshing?
I would not touch the pinion at all, for any reason, unless something is wrong with it. The one exception would be if the pinion shaft seal is leaking. A special tool is specified for this job (to measure 'friction moment') but many techs simply mark the position of the nut before & after (this also means you *must* re-use the old nut, and old flange). Crown wheel play (backlash) and housing pre-load can be measured using home-made tools and a micrometer/dial-gauge.Was there any special tooling you needed Rouven to check the pinion gear pre load, pinion to Crown wheel play and housing pre loading?
Some questions:
1. How did everyone like the wavetrac LSD in the end? Noisy/clunky, or not?
2. Who are these blokes on ebay advertising $1245?
3. Does this thing come with some instructions for installation?
4. Did anyone ever find the appropriate c-clips for the stock axle stubs?
@atg @gsxr - are these the c-clips that are needed when installimg a wavetrac diff? (The 203 part number)1) There is zero noise or clunkiness from the WaveTrac, Quaife, or factory clutch-type LSD. But unless you track your car, it's questionable if you'd ever notice the difference with normal street driving.
2) No idea about the eBay vendors.
3) Zero instructions. Either pay a rear-end shop that knows how to do Mercedes diffs (this is critical!), or DIY it with the FSM (advanced job, tool fabrication required).
4) Yes, I thought at least with the group buy the clips were included, but WaveTrac probably cheaped out and didn't put them in the box. The part number should be buried in a thread somewhere.
@Jlaa there should be 2 of those clips in the OE packaging in the Wavetrac box somewhere. Maybe wiggled between the foam packing.Yup, you want the 203- clip for Quaife or Wavetrac.
The 115- clip is for factory 124/129 differentials.
Oh I see it now! Thank you!@Jlaa there should be 2 of those clips in the OE packaging in the Wavetrac box somewhere. Maybe wiggled between the foam packing.
Thank you for setting wavetrac straight! I bet you didn’t think that people would be thanking you for this work nearly 10 years later!Nice that Wavetrac included those. I worked with them to develop this unit, and had to convince them that yes, a snap ring was needed to make the stock axle flanges work. I think they wanted to require people to modify the axle flanges and I said "no way". Ended up sending them the clips and part number, along with some other stuff...
Yes. You would need a spacer and longer bolts to attempt to fit 3.27 gears.I'm looking at upgrading my 300E differential to a 210mm unit from a W140, I already have a Wavetrac fitted to my 560SEC. Question is the W140 unit I have located from a S320 has a 3.27:1 ratio. Is the Wavetrac definitely only suitable for 2.65 to 3.06?
Give Jeff @ Byrd's Garage in the UK a call. Quaife has Bunch more options for ring gear back spacing and the exchange rate is Handy for us current;y!@Many thanks, I wasn’t aware of the ABS sensor change, will keep looking for a more suitable differential.
