Part 5- Re-assembly and final adjustments for smooth operation
This is the final section of the DIY which details re-assembling the sunroof and making some adjustments as you go to ensure the lid position is correct when closed and for smooth operation.
The adjustment stages are not 100% required but they are recommended when doing a full rebuild like this. To carry out adjustment you will need some vernier callipers (For centering the panel) and for setting the rear lid height adjustment a pair of regular 6mm drill bits are acceptable. If you have replaced the lift arms, sunroof lid or did not make complete markings of the bolts as you went then additional tools will be needed from Mercedes; (Courtesy of w124 performance)
I could simply say – “assembly is the reverse of removal”- which for the most part is true. However in the following steps I will detail the ‘full’ re-assembly and adjustment steps I would recommend-
1: Lubricate the section of rail pictured below of both sides with a light coating of Gleitpaste. Set the lift arms back in and slide them backwards out of the way
View attachment 62374 View attachment 62375 View attachment 62376
2: Lubricate the channel in the side trims as pictured and re-install.
View attachment 62377 View attachment 62378
Make sure the lift arm is correctly seated into the side channels-
3: Re-install the transport bridge and tighten the bolts back to the original markings made before removal
View attachment 62380 View attachment 62381
4: Re-install the gutter and don’t forget the little fibre washers first. Apply light oil to these connections
View attachment 62382 View attachment 62383 View attachment 62384
5: Now install the 4x remaining new felt pads onto the sunroof lid. I find it easier to Gleitpaste the back side first of each new felt pad then fit on and Gleitpaste the remaining sides.
View attachment 62385 View attachment 62386 View attachment 62387 View attachment 62388
6: Fit the MB tools both sides as pictured. (The tools are handed and marked L /R)
View attachment 62389 View attachment 62390 View attachment 62391
7: Set the Sunroof Lid back into place
8: Now to check / adjust the side to side placement of the lid in the opening. Loosen the front most 4x 8mm bolts as pictured (2x per side) Use the callipers to check both gaps and adjust as required before re-tightening the bolts again.
View attachment 62393 View attachment 62392
9: Re-fit the top sunroof lid nuts back on to the original markings made on disassembly.
10: Check the rear lid height. Mine was low both sides. Slacken the bolts pictured and lift the lid up to the correct height before re-tightening. This can take several attempts to get just right. Do this on both sides obviously. Then once set- remove the red tools both sides.
View attachment 62395 View attachment 62396 View attachment 62397
11: Now it’s time to fine adjust the sunroof lid front height in the opening. (This must be done now prior to the Stainless trims going back on) One screw as pictured both sides adjusts the front height. Again mine was low here too prior to adjustment.
View attachment 62398 (Note- I forgot this pic and took it after the trims were installed - it should not be adjusted with the trim plates on!)
12: Slide the lid back to open. Apply a light coating of Gleitpaste to the underside of the top stainless trim as pictured and re-fit the stainless trims both sides.
View attachment 62399 View attachment 62402 View attachment 62400 View attachment 62401
13: Now lubricate and adjust the front anti draught flap. Lightly oil all of the hinge parts and the top of the trim here-
Then there are 2x adjustment screws. This one adjusts the ‘stand up’ height with the roof open-
And these small screws adjust the flap in the lowered position as the roof is closing the last few inches. I find these always need tweaking to stop the flap rubbing on the lid as it closes.
13: Roll the lid fully closed and make sure both plastic brackets are positioned as shown below-
14: Re-install the fabric liner by inserting from outside. Set it in first – then check inside that the channel lines up before pushing it back in.
View attachment 62407 View attachment 62408
Roll the lid forward again about 3 – 4 inches and re-pop on the 4x plastic clips. Check that the fabric liner is correctly attached by using the ‘tilt up’ function of the sunroof. It may take several attempts to get both sides to ‘catch’ on the fabric liner brackets correctly. (It took me 4x goes on this one!)
And that is it! One re-assembled sunroof – and you CAN do it at home. It’s a half day’s tinkering for a DIY’er and highly recommended to do it sooner than later before the sunroof might stop working / jamb given that 99% of w124’s will have never had the felt pads replaced or the sunroof overhauled like this. If your sunroof is making any kind of scraping / groaning noises STOP using it until overhauled.
If it breaks a lift arm and won’t open it’s a whole lot of trouble – I will detail that kind of repair in a couple months.
