Re: Power Steering Pump Leak Investigation
Well after the reseal of the reservoir and pump and the cam solenoids and putting it back together... I am not noticing any improvement in the power steering, it's the same state.
On top of that 2 sounds came up:
- when you turn the wheel as if the system is low on PS fluid. It's not, I checked and added on running engine
- a weird buzzing sound from the left bank (driver's side). Can't tell if it's from the cam solenoid, the cap and rotor or the pump. Sounds like it's from the top. I did tighten everything accordingly so don't know.
kind of disappointed that PS didn't improve. At leaste I resealed the cam solenoids. Now I have to investigate the sounds. I'll post a video for clarity. Meanwhile, anyway to bleed the system out from air? I remember when I got the car the "smooth" 1 finger PS was available now and then and gradually disappeared.
