If you remove all of the cam bearing caps, be sure you do so in the correct order of removal and reassembly. If you remove them one at a time (for installing the oiler tubes, as I did above) then you just re-assemble how you removed each one.
In Roma's particular case, I am not 100% convinced of this. Look at the photo below from my engine. You can clearly see the green paint on one of the cam bearing caps. It is a much brighter and clearer green, and in a different position, than the darkish green/black/brown residue on Roma's cam bearing caps. Furthermore Roma's residue is on every cap and in a different configuration (not daubed on by a brush in a fairly consistent manner).
The fact that Roma's residue comes off easily with a fingernail (whereas mine did not, as I cleaned every cam bearing cap) also indicates that it is not green factory cam bearing cap paint.
As I said, I have no problem using a mild wire brush (as I indicated above), carefully cleaning and inspecting afterward, to clean anything that is stubborn and needs cleaning. In the case of a cam bearing cap, I agree that it would best be cleaned while removed from the engine, as I did my own when I documented the job above.
Most likely greenish residue is something that contains in oil ( fully synthetic mobil-1).
Yup I m planning to replace tubes one by one as you did. I read your report so that I know all short details like to lubricate cam bearings
I m also planning to pump out all the oil seen on a picture and then perform the oil change .
by Gerry.
