+1 on avoiding the ETA hose. If the ETA is original, removing it could disturb the wires with the ban insulation, resulting in needing to replace the ETA along with the hose. If the ETA is already replaced / rebuilt, then it's not a concern. Either way, it's a nuisance to pull the ETA to replace the hose... thankfully it only needs to be done about once every 10 years or so.I did not replace my rubber vacuum tube that runs to the ETA because I was scared of it and thought it could wait until later.![]()
Here are some tips and tricks that I cut and pasted from a post I think on PeachParts forum on doing this job. I had emailed this to myself some time ago before I did this job, and a few of the tips were useful as I planned it out. I was getting ready to delete the email and thought the tips were valuable enough to add here, for any folks who want to do this job in the future.
This is a moot argument. Not worth further discussion.
Thank you for the kind feedback.Just want to say that this site helped me out more than you could imagine. Even though my car is a "97" S-500, I found all the info very close to being correct for my model. I had gone to three different mechanics getting their opinion as to how to solve my problem of valve noise, and was told every BS story in the book from guys that should know what they were talking about. One guy even told me I over reved the engine and bent several pushrods. Seems to me a dual cam V-8 engine is made to be reved, even though that is not what happened (plus it doesn't have push rods). I have already done the passenger side and that's where most of my problem was, found three tubes with the caps blown out. This was the first time I've had a wrench in my hand in thirty years. I'm 70 years old and was a truck owner-operator back in the 1970's, before that I was a heavy equipment and truck mechanic for ten years so I have a little experience under my belt! Just want to say thanks Jerry, you saved me a lot of $$$ and helped me restore some faith in myself that I can still fix a car when I have to.
I'm running a special on factory re manufactured aluminum oil tubes. $110 shipped on the US.
I believe Justin does exactly that, where most other sellers do not.I do not believe that J-Sauce-sold metal oiler tubes would be materially different than those sold by another individual, unless the Sauceman perhaps put new o-rings on them, or removed any oil varnish, etc.
they were blue, not red, so they do give me an extra hp or two since I'm gliding the wake of the doppler shift of the higher frequency color.
RE: metal oil tubes engine number break.
Aluminum tubes:
119.970 up to eng# 031253
119.971 up to eng# 015654
119.972 up to eng# 002822
119.974 up to eng# 007126,
119.975 up to eng# 008748
Not necessarily. See post #39. It's a good possibility, but you must visually check your tubes via the oil fill cap. The info at the link in post #39 conflicts with the break points shown above.My engine number 119974 12 006313. Does this mean I have metal oil tubes?
1) Not sure about the green mark, but I'd ignore it.
2) Timing chain doesn't appear to have abnormal wear.
3) That engine is cleaner than average, IMO. It looks very good.
4) <shout> DO NOT USE ANY SEALANT ON THE VALVE COVER GASKET!!! </shout>
4b) Make sure you replace the copper seals on the valve cover bolts
4c) Torque the valve cover bolts to spec of 9Nm for all bolts you can get a torque wrench on
5) Valve cover bolts can be re-used if the socket heads are not rounded or stripped
6) I would not use that sealant for the cam solenoids. I would use the proper anaerobic sealant. However you could use it, and it may work fine, but next time they have to come off... ugh.
Here is my turn to replace valve cover gaskets which became like a stone.
I am also planning to put metal cam tubes.
I took off the valve cover and found couple of suspicious things.
1) What is this greenish stuff ? (circled)
2) What are those marks on the timing chain mean ? (immediate replacement ?)
3) Is the engine clean ? or somewhat clean ? or dirty ?
4) Regarding valve cover gaskets. Should I use sealant on the corners ? I got a black MB sealant (attached pic)
5) Is it required to use new bolts for valve covers ?
P.S. Can I use this sealant to seal the cam solenoids ? (may be stupid question but I m beginner at replacing parts like that)
Your comments are highly appreciated.![]()
1. Don't worry about that blotch ... likely just oil residue. If you want to get anal, just take a toothbrush or mild wire brush and scrape it off. I don't worry about that stuff. Don't worry, your car doesn't have herpes or a cold sore....
3. The engine is definitely cleaner than most. But not as clean as mine was![]()
4. Do not use sealant / RTV on the valve cover gasket. If the MB manual doesn't specify it, please do not use it.
5. For the cam solenoids, you should ONLY use the orange stuff that MB specifies, which is an anaerobic sealant specifically designed for metal to metal surfaces like cam solenoids and timing covers. It's the same stuff I mentioned in this thread and also in my recent M104 Top-End Rebuild thread, which smells citrus-y and is made from Japanese satsuma oranges and ground-up Koala Bear claws. This is what gives the sealant its bonding power (similar to the white Elmer's Glue, which is partially made from ground-up horses' hooves).
Why did you buy that black stuff anyway? It is not required for this type of job.
Yes Sir, pic attachedOnly use MB valve cover gaskets -- do NOT use aftermarket gaskets. You will need a 5mm swivel allen socket for the rear bolts on both sides.
Perhaps a good time to get your valve covers powder coated red or blue or some other cool color. You know .... for more of this ......![]()
I think red would be pretty cool.
You could hydrodip them.
I know the chicks dig that.
If you're going to powder coat the valve cover... DO NOT have the power coater blast them with anything other than soda or walnut shells. If they use sand or AO it will embed itself into the magnesium and work its way loose during the repeated heating/cooling cycles. Which is the last thing you want near any oil. It's like using grinding paste in the engine.
Don't ask me how I know....
Kind Regards,
Ron
What is that ?
Any documented proof ?
Brabus = Red
Carlsson = Blue
Take your pick.
I think if it was me I'd go with Yellow though.
These guys aren't very good at getting the pattern straight but you get the idea.
[video=youtube;rZGokzth7f4]https://www.youtube.com/watch?v=rZGokzth7f4[/video]
The green marking indicates the size of the bearing caps.
I would NEVER use a wire brush to scrub off anything inside an assembled engine.
The risk of wires falling in is way too high!
In Roma's particular case, I am not 100% convinced of this. Look at the photo below from my engine. You can clearly see the green paint on one of the cam bearing caps. It is a much brighter and clearer green, and in a different position, than the darkish green/black/brown residue on Roma's cam bearing caps. Furthermore Roma's residue is on every cap and in a different configuration (not daubed on by a brush in a fairly consistent manner).The green marking indicates the size of the bearing caps.
