I live in Houston, TX and it is HUMID! I have had all the issues various times, but in addition to all the fixes with slots and new ignition components, I removed everything from the cam area and soaked a rag with WD40. I wiped every surface of the units removed, and then soaked the rag again and wiped down the entire area of the aluminum for the cam area hosting the ignition. (I had replaced cam seals several years ago and also new cam adjusters) I had no leaks from cam seals or other components - and I have made multiple short trips, sit for 3-4 days, more short trips then long ones. No issues what so ever with the wd40 treatment. Leading up to this I would need to let car start 10 mins early and let the temp rise to operating temp before backing out of the garage over fear of stalling. (slightly exaggerating) but the fart/burps in reverse were rally bad right after initial temp idle reduction.
So I resolve to wipe this sucker every 4-6 months as needed - its just incremental when you live on the gulf coast or anywhere with heightened humidity. YMMV
