Hello All!
Two weeks have gone by and this is my first real update of 2018.
As the work is now out of my hands, I’m guessing updates will be slower!
The beast was taken to the body shop last week.
After mucho sucking through teeth, a price was agreed for the work. It’s the most expensive respray they have done for me.. Almost double the cost of the SEC Widebody back in 2008.
I think they learnt from the SEC job. Think of a number, triple it. May just about cover the inevitable surprises involved in jobs for me!
Hopefully the results will be worth it.
The major headache of the bodywork, is how to get the 500E bumpers to fit an estate. The mountings are different and the estate bumpers have “ears” below the tail lamps..
As you can see they are experimenting. We are using as much of the 500E bumper as possible and then grafting on the estate pieces. Once it’s all lined up, it will all need to be stitched and plastic welded together where possible. This type of plastic doesn’t “weld” very well, so we will see what tricks they pull out of the hat!
The bumper will have to be extended on the upper edge where it meets the quarter panel.
The centre rubbing panel will be a combination of the saloon part which has longer sides and the centre section will be the estate part.
The chrome trims are another challenge. The hockey stick shaped chrome tops don’t quite reach around far enough.
So much to think about when it comes to the bumper.
The rear quarter panels have been strengthened from inside. They have been pulled out to remove as much of the distortion as possible. Finally they have been filled to achieve a flat finish. The body shop will wait a few days for this to go totally hard, before they sand it back.
Thanks!
Thanks!
