Thanks Sir.Pic attached.
Nice going Gerry. I am sure that your wife is ready to get her wagon back.
I hope to do this one day....
Good to hear from you here. You know, there are still some decent, low-miles HFM E320s out there, often blue-hair cars. I remember when you got your 210, and I have often wondered about your opinions about your experience with the newer car as compared to the older one. I would not say I have MISSED the 6.3 I owned, but it would certainly have probably doubled or tripled in value since I sold it in 2004 or so. Hard to believe when we met it was 11-12 years ago !! Time flies.What a fantastic write-up, Gerry. I read every post and clicked on every picture. I enjoy my 2001 E430, but I wish I would've held onto my former 1993 300E (3.2). It was a fantastic car.
I still remember fondly the ride you took me in in your 300E 6.3 when you lived in Portland. That was a nice car.
Don't be a stranger here.
My goodness, indeed!! Thanks for the heads up. I'll change that to the correct orientation. I just received a parts order today from MB, that includes the pin that the lower edge of the front plastic covers slides onto. As far as I know it wasn't there when I took the engine apart (and I don't see it in your photo either) but I see the bung in the timing cover for it, and the groove at the bottom of the plastic cover, and the EPC said I could order it, so I did.Nice job Gerry.
The only mistake I saw in your pictures was the ground wire by the switch over valves in front of the upper timing cover.
As you can see in your picture you placed the wire behind the bracket, it should be in front under the bolt head.
Here's a picture of an original M104 before doing the cover reseal below your picture.
I've also done several of these upper cover reseals and the ground
wire is always under the bolt, not behind the bracket.
Honest mistake I'm sure. Great job, love the red cylinder head cover.
My goodness, indeed!! Thanks for the heads up. Thanks again for pointing out the inaccuracy on the ground placement !
Here's the ground connector as I removed it. The ring connector was indeed directly under the bolt head, as you indicate.
WOW... talk about a late 1995 build. That would have been a 1996 model year if Mercedes had kept the 124's coming as 96 models into North America!I have three w124 cars a 1994 e320 sedan and two 1995 wagons. One of the wagons is serial no.341788 and a build date (door jamb) of 11/95.
Jeff
Given that our friend Clark Vader (aka Bob_036.....aka "Clarkzturbator"...etc.) had identified the very critical problem with my re-installation of the ground wire BEHIND the switchover valve instead of IN FRONT of this valve, I removed and repositioned the ground wire to its proper position.Nice job Gerry.
Working on it now. One to two panels per night. Takes time to do it right.You cleaned that wagon up yet?
I have one slight issue, and that is the car takes a bit longer to start when the engine is warm. You have to crank on the starter for about twice as long (3 seconds) to start it. When the car is cold (not started for 3-4 hours) or hot (just go into a store for 5-10 minutes) it starts perfectly. But when you leave it for 15 minutes to a couple of hours, it takes longer cranking to start up. So I am slowly working on diagnosing this, but the fuel pressure is fine (leakdown is according to spec). I have also removed and checked the plug/coil connections and all is perfect.
The car is running absolutely smoothly and perfectly and I would say is developing probably 15% more power (especially at low RPMs/off the line) than it did before. I can really feel the difference and the power curve is really amazing when it comes up on the cam at maximum acceleration.
I don't think it's a wiring harness issue because the upper harness has been replaced in 2006 with a new, MB known-good-wiring harness. The lower harness is brand new and didn't change the situation (I didn't expect it would; it was original and just needed changing).IMHO, it could be temp sensor failure? Intake air, water temps.. OR wiring harness problem?
That's a good news! I thought I wouldn't feel any significant change because my engine doesn't have any problems except minor oil leaks.
Indeed, that intake air flap was a great innovation they did on the M104. Those buggers are spendy -- I cannibalized the one on the extra intake manifold I got at the wrecking yard as a spare, because IIRC they are pushing $500 dollars new from MB!What you're feeling is a combination of the variable intake cam timing and manifold resonance flap.
More the flap, which increases intake volume flow like the old domestic V8 performance intake manifolds.
Like going from a dual plain street manifold to a race single plane manifold (Edlebrock)
In fact, Yamaha had the same thing on the 1984 V-Max. They called it V-Boost
It's quite impressive, good low end torque, then great peak HP
Mercedes claims around 20hp increase, though I'd have to check WIS
That number is off the top of my head from memory.
By the way, did you see that I "fixed" my ground wire at the switchover valve so that it's in the correct position?
Indeed, a lot of so-called "rebuilds" don't actually replace much in the way of internal components ... they just reseal them and replace the things that have failed, and call it good.The factory in Germany basically puts ALL new parts in a reconditioned used case. As new as you can get.
You want Sun Valley to reman your transmission. the best shop I've heard of in the US specializing is all years of MB gearboxes.
<SNIP>
Yes, I am not looking forward to this, but as always will document the removal as best I can for others who need to do it in the future.Oh, the top-two is, yes, difficult to access. I used long extension (about 60cm?) and swivel joint, and obviously, tightening them was also frustrating.
I've done for my 722.4 3 years ago (I had no reverse), I felt that disassembling and re-assembling are not so difficult but measuring and adjusting are important.
Ganbatte!
This is the one car that I don't track the mileage on. However, when I drove it from Oregon to Houston, TX back in 2008, I did keep track of the mileage, and will pull it up and post it when I get a minute.Is there any way you could please post a "fuelly" on this car too?
Interesting - my car nor any other I have seen has had these insulators. I even looked at a 1994 E320 in the wrecking yard today, and didn't see anything like that when I unbolted the Allen bolts holding that cover onto the top of the valve cover. When you get yours installed, can you take a photo? I'd like to put them on my car.Gerry, our '95 wagon had two plastic insulators (104.159.14.40) that insulate the ignition wires from the two front coils. The rear coil does not have an insulator, since it only has ONE set of ignition wires running parallel to the coil. Mine were very fragile, and broke when breathed upon. Current retail is $7.00, parts.com: $5.25
