I thought they were NLA as well. Good to know that you were able to get them.I just received those on Friday
5: Get inside the car and roll the Sunroof lid fully forward again. Carefully mark the exact location of the brackets and fixing bolts before undoing anything. I use a sharpie and a scribe to mark them.
I'm about to start this job. Joe, explain to the idiot why the bolts need to be marked? I see in your picture you drew a circle around the bolt with a sharpie... Thanks8: Back inside the car now start by undoing the 2x 8mm bolts that secure the Cable to the Transport Bridge. Then mark the 3x bolts either side and remove them also.
I *think* the idea is, if you mark everything before disassembly... when you put it back together, you may not need to make any adjustments.I'm about to start this job. Joe, explain to the idiot why the bolts need to be marked? I see in your picture you drew a circle around the bolt with a sharpie... Thanks
I'm about to remove metal lid. When someone a lot smarter than me does something I need to understand. In this picture, Joe circled the washer and drew an arrow pointing at it. Looking at my own, I can't figure out how that's helpful...I *think* the idea is, if you mark everything before disassembly... when you put it back together, you may not need to make any adjustments.
![[500Eboard] IMG_5428.JPG [500Eboard] IMG_5428.JPG](https://www.500eboard.co/forums/data/attachments/128/128314-3da987bff8f0c6002cc5a1dc79e33fef.jpg?hash=PamHv_jwxg)
Dave, those nuts/washers combos that are marked on your picture "Ok to remove without marking". I had 3 come out easily, but 4th had to mangled. Can you tell if #42 is the one? ThanksI think the ones on top can be removed without marking. Those just hold the roof panel to the side bracket.
Now, the ones on the side... those you don't want to touch if possible. If not replacing the lift arms, you can leave those alone.
@JC220, what's your rationale for using oil on pins and plastic bushings of lift arms?FSM says to use Gleitpaste on all the felt pads, and all moving parts of the lift arms. That's what I used, I did not apply oil anywhere.
Simple. No grease can penetrate the joints/ pins whereas oil does and the effect is immediately apparent.@JC220, what's your rationale for using oil on pins and plastic bushings of lift arms?
Pretty sure 126-782-01-30 goes here:
On a related note, did the tiny ones (124-782-01-30) have felt coating, or were they plain rubber? The ones I received from the dealer last summer had no felt fuzzies.
I just replaced all those sliding pieces on both arms. Both smaller sliders (that are now rubber) were missing and one of 126-782-01-30 was missing from one of the arms. Rest were in place and although old and worn, they were far from gone. If cleaned up, they could be justified to be sold as "used, very good condition".Pretty sure 126-782-01-30 goes here:
Make sure and use a good quality super glue to fix all of the pads in place! Otherwise they will go missing again in future. Glued on and kept lubed with Gleit will keep them rightI just replaced all those sliding pieces on both arms. Both smaller sliders (that are now rubber) were missing and one of 126-782-01-30 was missing from one of the arms. Rest were in place and although old and worn, they were far from gone. If cleaned up, they could be justified to be sold as "used, very good condition".
One definitely experiences a "high" cleaning lift arms from old grease and putting on new felt sliders
It'll be a while before I'm qualified enough to have the arrogance to deviate from Your write-upsMake sure and use a good quality super glue to fix all of the pads in place! Otherwise they will go missing again in future. Glued on and kept lubed with Gleit will keep them right
 I think I can make STL file for 3D printing them in the future for everyone who needs them.
Check for anything sticky that may have been left from painting. I didn't know about pushing the roof forward. Try that as well.Thanks to this write up, I just about finished servicing our 500E sunroof. But I have a question about adjusting the height of rear of the sunroof. Here's the situation. When I open and close my sunroof, the rear of the sunroof ends up a little low. When I use the tilt function and close the sunroof, the rear of the sunroof ends up a little high. So, when do I adjust the roof, after the tilt function or after the normal open and close?
I'm afraid if I adjust higher after normal operation, then it will sit higher still after closing from the tilt operation.
When it ends up low, I can put a little pressure from underneath and raise it a bit, and the same when it ends up a little high, I can push it down to level. It feels like maybe it is just friction with the gasket? The gasket has not been replaced, but the roof was just painted... I guess I need to find out whether the gasket was removed and reinstalled for painting.
These are again available from MB. The part has gone to a new supplier, and the current (revised) part number is: A124782003064FYI... MB Classic shows these may be orderable, although possibly unavailable, so the order may be cancelled. Spendy buggers, $23+ list price, 4 total.
https://partssearch.mercedes-benz-classic.com/parts/A1247820030?tt=automatic
As Joe mentioned previously, these large rectangle pieces can almost always be re-used.
Hey JC220, turns out that's what happened to me and I assume my lift arms are broken as the motor still whirs and the right arm slightly moves but the left seems to have jammed completely during tilting. Do you have a link to your repair post by any chance?If it breaks a lift arm and won’t open it’s a whole lot of trouble – I will detail that kind of repair in a couple months.
So again, even if available, if old ones are in good shape can they be reused? I mean 20 bucks a piece geesh. Is the felt coating really necessary? Or can older ones in good shape that are mostly just rubber feeling do okay with gleitpaste?These are again available from MB. The part has gone to a new supplier, and the current (revised) part number is: A124782003064
Some can be re used yes. However in order to make this assessment you must remove your rails first then inspect the buffers and see which ones are worn / missing to order the minimum required if you wish to go that route.So again, even if available, if old ones are in good shape can they be reused? I mean 20 bucks a piece geesh. Is the felt coating really necessary? Or can older ones in good shape that are mostly just rubber feeling do okay with gleitpaste?
The old grease will be Dry in the tube yes but don't worry about that at all. New grease on the cable will pull in down the tube and it will work perfect. Don't bother with brake cleaner as it won't go far due to tube construction. It will leak and damage your headlining.Also, if the grease on the sunroof cable was dry (my motor did spit my cable out about 8 inches, and I had to pull hard the cable the rest of the way out of the tube, and the grease on the cable was very dry). doesn't that also mean the tube itself is gummy too?
If I shot brake cleaner using its red straw attachment down the sunroof cable tube, would I risk the brake cleaner eating the nylon gears inside the motor?
I know Ertech this is an old post and not sure if you are around, but how did you put a drill on the cable to spin it in? Mine has the butterfly end so there's nothing for the drill to grab.Finally got the cable in I used a drill at very low speed to push and rotate at the same time it went right in
How do I remove this butterfly piece I already removed the pin not sure if that was necessary thanks guys
You mentioned the side to side gap, but what about the front to back gap? It almost appears that the gasket is thicker on the back than it is the front, as if the roof is scooted toward the front a tad more. (less front to back gap in the front, and more front to back gap in the back).? Or is it the same gaps on the front as it is the back?Part 5- Re-assembly and final adjustments for smooth operation
This is the final section of the DIY which details re-assembling the sunroof and making some adjustments as you go to ensure the lid position is correct when closed and for smooth operation.
The adjustment stages are not 100% required but they are recommended when doing a full rebuild like this. To carry out adjustment you will need some vernier callipers (For centering the panel) and for setting the rear lid height adjustment a pair of regular 6mm drill bits are acceptable. If you have replaced the lift arms, sunroof lid or did not make complete markings of the bolts as you went then additional tools will be needed from Mercedes; (Courtesy of w124 performance)
I could simply say – “assembly is the reverse of removal”- which for the most part is true. However in the following steps I will detail the ‘full’ re-assembly and adjustment steps I would recommend-
1: Lubricate the section of rail pictured below of both sides with a light coating of Gleitpaste. Set the lift arms back in and slide them backwards out of the way
View attachment 62374 View attachment 62375 View attachment 62376
2: Lubricate the channel in the side trims as pictured and re-install.
View attachment 62377 View attachment 62378
Make sure the lift arm is correctly seated into the side channels-
3: Re-install the transport bridge and tighten the bolts back to the original markings made before removal
View attachment 62380 View attachment 62381
4: Re-install the gutter and don’t forget the little fibre washers first. Apply light oil to these connections
View attachment 62382 View attachment 62383 View attachment 62384
5: Now install the 4x remaining new felt pads onto the sunroof lid. I find it easier to Gleitpaste the back side first of each new felt pad then fit on and Gleitpaste the remaining sides.
View attachment 62385 View attachment 62386 View attachment 62387 View attachment 62388
6: Fit the MB tools both sides as pictured. (The tools are handed and marked L /R)
View attachment 62389 View attachment 62390 View attachment 62391
7: Set the Sunroof Lid back into place
8: Now to check / adjust the side to side placement of the lid in the opening. Loosen the front most 4x 8mm bolts as pictured (2x per side) Use the callipers to check both gaps and adjust as required before re-tightening the bolts again.
View attachment 62393 View attachment 62392
9: Re-fit the top sunroof lid nuts back on to the original markings made on disassembly.
10: Check the rear lid height. Mine was low both sides. Slacken the bolts pictured and lift the lid up to the correct height before re-tightening. This can take several attempts to get just right. Do this on both sides obviously. Then once set- remove the red tools both sides.
View attachment 62395 View attachment 62396 View attachment 62397
11: Now it’s time to fine adjust the sunroof lid front height in the opening. (This must be done now prior to the Stainless trims going back on) One screw as pictured both sides adjusts the front height. Again mine was low here too prior to adjustment.
View attachment 62398 (Note- I forgot this pic and took it after the trims were installed - it should not be adjusted with the trim plates on!)
12: Slide the lid back to open. Apply a light coating of Gleitpaste to the underside of the top stainless trim as pictured and re-fit the stainless trims both sides.
View attachment 62399 View attachment 62402 View attachment 62400 View attachment 62401
13: Now lubricate and adjust the front anti draught flap. Lightly oil all of the hinge parts and the top of the trim here-
Then there are 2x adjustment screws. This one adjusts the ‘stand up’ height with the roof open-
And these small screws adjust the flap in the lowered position as the roof is closing the last few inches. I find these always need tweaking to stop the flap rubbing on the lid as it closes.
13: Roll the lid fully closed and make sure both plastic brackets are positioned as shown below-
14: Re-install the fabric liner by inserting from outside. Set it in first – then check inside that the channel lines up before pushing it back in.
View attachment 62407 View attachment 62408
Roll the lid forward again about 3 – 4 inches and re-pop on the 4x plastic clips. Check that the fabric liner is correctly attached by using the ‘tilt up’ function of the sunroof. It may take several attempts to get both sides to ‘catch’ on the fabric liner brackets correctly. (It took me 4x goes on this one!)
And that is it! One re-assembled sunroof – and you CAN do it at home. It’s a half day’s tinkering for a DIY’er and highly recommended to do it sooner than later before the sunroof might stop working / jamb given that 99% of w124’s will have never had the felt pads replaced or the sunroof overhauled like this. If your sunroof is making any kind of scraping / groaning noises STOP using it until overhauled.
Hey guys see the attached video of the issue I have after doing a total sunroof refurb, new felt pads, the whole works.Good points on the cable types guys a photo of both types is in post number 5 of this thread.
It's a great idea to nab spare late type cables at the parts yards since you can usually get them for next to nothing!
Yes springs and clips new and installed correctly. I AM the one having the deflector sit low because it is the only way to get the lid to skim above it and clear it.Have you replaced the springs / clips for the deflector so it pops up fully, and then followed the FSM procedure 77-250 for adjustment? Are you sure there is nothing missing on the metal roof panel where it contacts the small side arms, that should be pressing them down further?
Yes I haven't had this issue either. I would surmise there must be something missing or broken on the deflector and it should be carefully inspected.Something clearly ain't right but I'm at a loss to explain it. Maybe @JC220 has some ideas. If I'm reading the FSM correctly, the spec is 5mm air gap between the leading edge of the metal roof panel, and the plastic deflector, when properly pushed down during closing. I'll need to look at a couple of my cars for reference - never had the problem you're encountering.
I wonder if the two black metal prongs that the sunroof deflector has that the springs slide over maybe are bent? But then again that little plastic clip that holds the spring terminating end to the deflector wouldn't click in nor the prong slide through the spring if they were bent? Again sorry for late reply, work is kickin my butt and I'm getting to this as I can.Yes I haven't had this issue either. I would surmise there must be something missing or broken on the deflector and it should be carefully inspected.
When you say pull inner panel down, do you mean the sunroof liner piece? Meaning pull the sunroof liner down out of the opening into the inside of the car instead of up and out of the opening of the car?Thanks for this amazing guide! Two things: First: if you can’t move your roof back, don’t go for the “whole cassette” thing. Pull the inner panel down and bend it slightly to get it out, without opening the roof. That’s my take anyway… Second. I had everything working, slide and tilt. Then I would, ever so slightly, adjust the rear height, loosened the two “horizontal” nuts on the bracket on each sidez Height is fine but suddenly it won’t tilt up anymore. Will look into that later, but hints are very welcome!
