Always wanted 944, but the Turbo nosed, and rear apron fitted, so the choices would have been the Turbo or S2. Well, 1989 S2 came along, right price, local car, right color combo for my taste, and "Red Sonja" came home with me.
Perfect she is not, definitely a driver quality car, but solid, no accidents, nothing major, just lots of age related TLC is needed.
Here is the short list of things that definitely requires attention:
Porsche 944 Parts Interchange / Cross Reference List
And so it begins!
D
Heat, always on, probably stuck open, may need Heater Control Valve 0148000052 or Metal clip/lever off, details here944 HVAC, Clark's Garage- now switchable, but manually only.Blower operates on 4 (likely the "relay" is the culprit asoutlined in this thread)- AC, converted but inop, that will tackle later, griffiths.com for the parts
- Coolant leak, very small, throttle body (possible fix discussed here)
Power steering pump wine and possible leak (Rebuild kit 10-7407-001-M995 ) Rebuild DIY andPump RemovalPower steering reservoir leak (ZF 928-347-015-05-M103)Gauge showing 12.7V while driving:(AutohausAZ Bosch 30097 $33)Slow old battery(replacing with 700CCA unit)Driver's side door pocket, plastic trim broken, repairedWindow switch, driver's side plate for passenger window, inop, will replace, interchangeable(with panel, Ebay, $20)Rear View Mirror, off the windshield, will glue back(Autozone, glue, $7)Climate control trim plate cracked, will replace(Ebay, all 10 trim pieces, vents, switches, bezels, etc $110)Aftermarket double din head unit, no trim plate, huge gap, will make facia/filler panel(Ebay, $15)- Tweeter grills, screwed on (shaking my head), will repair
Replace all speaker, full overhaul (Sizes and details on 10 speaker system)Fixed wires, added powered subwooferRear hatch creaks on the driver side, will replace both bushings(only944, pair, $27)Driver's door strap/check bracket, apparently that is one royal pain, (92853741703suggestions here...)was straight forwardPassenger side front bumper turn lens, cracked, will replace both(Only944, $70, clear, with bulbs)Driver side outer fog light filler piece, missing, will replace(Pelican $75 that's kind of a rip off, such a tiny end pieces)Rear passenger bumper corner cover, paint chipping/bowing, will replace(Ebay, L+R, red, $70)Motor Mounts- Dash defrost vents, starting to crack, known flaw on all these cars, and 968 too... will try to modify/adapt 911 trim (Ebay $50)
Intermittent tachometer(lets hope it's just a old cold joints pelican forums tach fix) and rennlist forum)- Calipers, dusty looking, will refresh the finish
Stone guards, clear plastic "sticker", both sides, old, cracking after 30 years, will removePaint correction and polish, my brother owes me a favor, that's his game, it will look great I'm sure.- Need Lamin-x for fog lamp lenses, as these are $$$
Caster Blocks - to be updated to hard/sport from Elephant RacingCV inner boots torn: replaced inner CV units, rebooted, and reg-greased all 4, new hardware
And so it begins!
D
