You can certainly remove the cams as an alternative to disassembling the intake cam adjusters, and removing the exhaust cam sprockets. I know some people have actually done it that way.Is it possible to do the upper chain rails in the cylinder heads by just removing the cams?While at the same time you are doing the cam oilers?
Or is that more difficult?
I addition to snugging all the aforementioned bolts, I also added an external bead of RTV around the oil pan and timing cover-to-block seams. Definitely not @Klink-approved or Jono-approved, but it sure beats pulling the timing cover to stop tiny leak that mostly just makes a mess...After that, I took my 5mm Allen socket, because I noticed just a slight sweat of motor oil along the front edge of the oilpan, in the recess where the line of oilpan bolts are. I snugged each bolt down about 1/16 to 1/8 of a turn. Pretty much every single bolt needed a bit of a snugging down.
For the record, what type of RTV did/do you use? Just wondering what type would lend itself to this type of application?I also added an external bead of RTV around the oil pan and timing cover-to-block seams.
For an external bead like this, I don't think the specific type is critical. I believe the orange stuff in that photo was Permatex High-Temp (Ultra Copper?) but I'd have to check the tube. It worked very well.For the record, what type of RTV did/do you use? Just wondering what type would lend itself to this type of application?
too bad that RTV does NOT come in an irridium silver color![]()
Interesting comment on your water pump. My '94 E500 also has the original water pump at 126,000 miles. Would you recommend replacement as a preventative measure?I've also decided overnight and this morning that I am going to replace the water pump, along with the planned thermostat replacement. Reason being is that I have done all of the work that would be pre-required to do the water pump, and drained the coolant. I have a spare, new water pump and gasket sitting on the shelf in the garage, and the water pump on the engine is the original one (144K miles).
It's literally incremental labour to replace the pump at this point. So, yet another task to do as part of this big job.
Trivia: The existing hole is not for airflow to the resistor. There is supposed to be a short rubber hose connecting a hose barb on the headlight, that routes out through that hose. This keeps pressure from the "airbox" around the headlight from entering the headlight, potentially causing condensation to be pushed into the headlight housing.The plastic headlight air scoop/bucket piece, as shown in the first photo below, has a SINGLE, dime-sized hole that allows air to flow back to the resistor when the car is in motion.
Are your coolant expansion tank and SLS reservoir still bright-white colored?@lowman,I mean @gerryvz, what a fantastic job. Were it not for you, I would not be rushing into the garage on a Sunday morning just to check to see if my car still has its tensioner pulley ornamental cover in place (whew it does!)![]()
for your interest !!Actually they are as hard as rocks. And I have new ones already, as well as a new heater lid, cap and little cap holder piece. Everything is laying in pieces on my shop floor.Nice work, Gerry. Those grommets on the windshield washer heater lines looked a little grungy, though. Shouldn't you replace them?
He doesn't always post. Sometimes he's absent for years at a time. But when he DOES post, he posts zingers.Your new heat exchanger tube grommets are pressed in upside down...
And I almost hate to point it out, because this is an epic thread that just gets epic-er. This is so outstanding, Gerry. Just damn!
That'll be all of 30 seconds to remedy, seeing as I haven't inserted the heat exchanger tubes yet. I'll provide photographic evidence for you and @LWB250 !!Your new heat exchanger tube grommets are pressed in upside down...
My new supply of copper washers came in from MB, so I'll be (briefly) removing this banjo bolt at the tandem pump and replacing both of the copper washers with fresh ones. This should help alleviate any leaks caused by re-using the old washers. It's OK to do this in a pinch, but best to replace the washers. They are cheap and available from aftermarket (AutohauZ) sources as well as from MB, for about 3-4x the price.Next, it was time to connect the banjo bolt fitting to the tandem pump. Unfortunately, I did not quite have the correct size of copper washer in my parts stock, so I had to re-use the original washers. I'll have to re-order a dozen or so new ones of this size. Frustrating! But I'll replace them after I receive a new stock of them.
View attachment 108628 View attachment 108629 View attachment 108630
These photos should get @Klink & @LWB250 off my back permanently, at least on this small topic.That'll be all of 30 seconds to remedy, seeing as I haven't inserted the heat exchanger tubes yet. I'll provide photographic evidence for you and @LWB250 !!
