I reset the all of the codes as well as the adaptation today on the LH module. We’ll see if I still get the zoomie cold starts happening.
I was going to deep clean the leather today, but got distracted with another project. Decided to take out the drivers side headlamp and inspect the fan resistor as the last step in troubleshooting my current running temp. Many posts talk about the heat load these little guys go through causing corrosion at the contacts, which leads to higher resistances in the circuit, which stresses out the already taxed 15 amp fuse. Given that my fuse was blown, I wanted to make sure there wasn’t anything fishy going on in there.
The FSM was pretty helpful in getting the headlight out. A few pics along the way.
Dirty side marker area
Headlamp out, mystery cable clip found in bottom of headlight surround:
Theres the little bugger:
Headlight surround out:
1st little safety cage removed:
Removed:
Contacts didn’t look too bad actually, but you can definitely see the heat cycling.
Wires didn’t look too bad either:
I hit them with a little sandpaper and acetone before I put them back regardless.
While I was dinking around in there, i noticed that the IAT sensor had somehow become trapped under the drivers side distributor trim, and was being held against the serp belt [emoji51]
I disassembled the connector:
And tried to get some appropriate heat shrink tubing around the pins. That was not possible. I used the next size up, but had to then cover it with electrical tape to get the loose tubing to stay in place. I then covered the whole thing in high temp electrical tape. Needless to say, it ended up looking like shit.
I had recently gotten a high temp soldering iron, so I figured that I would take it all apart again, and do it right.
Kinda sorta proud of those re-solders: [emoji3]
So much better!
I need to order a new sensor and a new connector.
Removed:
So much better!
