Tackled the brake booster this afternoon/evening. Thanks to @northNH for getting it to me promptly, greatly appreciated!
All in all, if I was rating this job from 1 to 5 with one being a cake walk and 5 being a total pig, I would probably give it a 3. It wasn't bad, but somewhat messy and not fun under the dash - but when is working under the dash fun?
Some observations that apply to not only the booster but also the master cylinder:
And a close up of the clip:
Bled the brakes and fired up the car. Power brakes!!! Woo-hoo!! Noticed some brake lines that need replacement while I was doing this. Took the opportunity to hit the fittings with Kroil in anticipation of removal. Fun! Brakes were a little spongy but not bad. Probably still a little air in the system.
Took care of a few other items while I had time or was in the neighborhood:
Right rear jack point bumper/pad was missing. Replaced with a new one.
Anyone recognize this part?
Wait for it....
Yup, a clip for holding down the front of the air cleaner box. Most people don't even know these are missing.
Put a new O ring on the oil dipstick. Old one was rock hard and shattered when I tried to remove it.
Called it a night. Left the panel under the dash off as I've got to replace the ASR switch on the accelerator which I'll do this weekend. I got a load of hardware in today so I can put this on the car this weekend:
I'll probably replace the third brake light this weekend as well, and install a nicer rear headrest (also from @northNH) to replace the one that has a split from sun damage.
- Everything *will* come out of the space. Really.
- Expect a mess.
- Remove the brake master cylinder reservoir. You won't get the master cylinder out without doing this.
- Once the master cylinder is free of the booster, you have to rotate it 90 degrees to the right (if I recall correctly) once it's off the mounting studs to be able to move it forward far enough to clear the booster.
- You only need to take the nuts off the booster mounting on the inside at the 4 o'clock and 11 o'clock positions. The other two are for the bracket.
- Be careful not to break the brake light switch when removing the retaining clip on the clevis pin. I used the infamous instrument cluster hook tool. Not easy to do, but it worked. I'm amazed at how many uses I've found for these hooks since I broke down and bought a set.
- If you have ASR, be sure not to mix up the connectors between the ASR pump and the level switch on the master cylinder reservoir. They're identical.
Wait for it....
