I agree, slots I've done - go much much deeper, even the factory slots I've cut deeper, and for quite some time, since the modification, zero moisture issues (my spare caps)The slots have been cut there that's good and thanks for sharing the videos!
The slots have not been cut deep enough however.
The cuts need to extend further like the factory ones on the lower edge. This is so they can bypass the O ring on the insulator cup behind and also the cylinder head alloy.
Dave- what are nominal voltages and durations? Low 30s for V and 1.5-1.9 for duration?Excellent diagnostics! This is exactly what I was expecting to see, abnormal voltages all related to one cap, likely the passenger side. The initial voltages of high 30's and low 40's were an early indicator even without misfiring. The ~70v readings will appear with a misfire.
Could you post a close-up photo of the slots you added to the cap? I'm wondering if they are not quite deep enough. @JC220 might have some input as well. With adequate slotting, AND after the engine is driven for 30-60 minutes at normal operating temp after the slots are added, maybe the issue will go away.
BTW, the strong odor should not occur unless there are active misfires. If you have abnormal odors with good ignition voltages, there may be a separate, unrelated issue (would need some LH live data when it smells funky at operating temp).
Thanks dave.Typical voltages are low 30's and they should all be reasonably similar. Big jumps to higher numbers (say, 40+) generally means something is fishy, and you'll see double voltage (70-ish) with a misfire on that cylinder. I can't recall the typical duration but the duration you see with low 30's should be correct.
I'm not quite sure about the LH values for odor, but I'd look at kg/hr, O2 voltage cycling, duration, and the on/off ratio to start with. This assumes the odor persists after the slots are enlarged and also at normal operating temps. I'm hoping the odor was related to the misfire and will go away.
Sweet! Yeah that would be one way to confirm for sure.Regarding potential source of water getting in the trunk, I had similar issue and it was the rivets under the windshield trim. Need to fix it, for now, I don’t drive in the rain
(Had jumped in the trunk like in the old movies and had someone soak the outside with a garden hose to find the leak).
light when I install this? I've read on this forum that I will, but I don't understand how the DM would be able to tell. The valve itself has no monitors, and I have a REALLY hard time believing that the O2 will be able to pick up a EGR 'signature' with high enough resolution to provide the ECU/DM with a way to check for proper ops...That’s it @a777fan , time to take the bulb out once and for allYeah, it will trigger the CEL. The DM compares intake manifold pressure changes vs what's expected with the valve open or closed.
Stupid early ‘90s sophistication!!!!Yeah, it will trigger the CEL. The DM compares intake manifold pressure changes vs what's expected with the valve open or closed.
Knowing you, you will find a very sophisticated and highly elegant technical solution for the issue. In my book you are a legend Jon, because Steve G. didn’t want to touch the ASR project with a ten foot pole and you implemented it beautifully. Thanks again for that!
I would doubt that gasket was really leaking that much if at all. You can test the integrity of the valve itself with a mityvac or similar vacumn testing tool. Pull a vac on it watch it close and see if it holds for a few minutes without moving or hissing.So… I installed the block off plate. But guess what I found… evidence that it was actually the gasket that had failed:
See that little smudge in the center cutout area of the gasket? It appears like the gasket sealing surface has failed in that area, and has been letting exhaust gas (or something else hot) through.
Theory: I replaced the EGR gasket when i did my top end refresh a couple of years ago, so its not the original. Since then, however, I’ve had multiple bouts of the wet distro cap misfires, which have on occasion, resulted in intake backfiring. I’m wondering if one of those backfires was potent enough to blow out the gasket and create a the vacuum leak?
Anyway- the blockoff plate is installed, and i took it for a fairly long drive in afternoon traffic. City, highway, stop and go. It performed pretty well. The occasional idle oscillation I have been experiencing (this is what led me to do the smoke test in the first place…) Did not occur on this drive. We’ll see if it stays away.
No check engine light yet, but as Dave states, I’m sure there is already a pending code. When it does pop on, I might swap the valve back on with a new gasket and check for leaks. I would love to keep the dash lamp free.
Oh, one more thing: has anyone ever found that their MAF housing is the source of a vaccuum leak? I was getting some wisps from that area, and it appears like its coming from the plastic MAF case where two of the sides meet at a corner and there is adhesive goo (sealant) applied.
Awesome that is so exciting to see! Looks like you are giving Uter some deferred attention.
Thanks All!@a777fan, Jon, something that happened to me when I changed my old 300E’s front end to Koni Red shocks an Eibach lowering springs. I torqued the bolts holding the lower A-Frame behind the brake rotor to the specified 85ftlbs (Not sure on that torque. I believe thats what it was.)
Anyway, After I drove the car I had a slight clunk in the front end. I went back thru my work and found that the bolts I torqued to spec were not tight on one side. It was kinda weird I could push/pull on the rotor and it had a little knock. I re-torqued (actually over torqued until it tightened up the gap) the bolts and it went away.
Point being, make sure the torque values are achieved on those bolts)
PS; This tidbit of info is from memory but it really happened but it’s about 25 years since I did that job. I can’t actually see the bolts in your pics but I’m pretty sure they’re behind the rotors.
Take Care
Yes! The Bavarian brothers have been diverting my attention, but now we’re back. Its nice to have it operable again, and this sportline upgrade is something I’ve been lusting after since I purchased it.Awesome that is so exciting to see! Looks like you are giving Uter some deferred attention.
Your phrase “it’s sportline time” made me think of “it’s skyline time…” which has nothing to do with sportline other than it rhymes, and that this commercial came out the same time period as when the w124 was selling ….
The monos were off 202, so the offset was never right up front and would rub going around turns at high speed etc. I love the look, but didn’t want to continuously be damaging the car. If I can find a w124 specific set at some point, I’d go back in a heartbeat, but those are like hens teeth.Yep looks better lower, why did you go back to the holies - just curious. (too lazy to find it)
Jon, what width/offset were the front wheels? If they were the 7.5" version from the front of a C36, those can be made to clear (with 225/45 tyres) if you roll the fender lips and add spacers at the bumper & fender leading edge. It's all in the AMG wheel install docs.The monos were off 202, so the offset was never right up front and would rub going around turns at high speed etc. I love the look, but didn’t want to continuously be damaging the car.
Bruno Sacco Approved SolutionI do like the ‘stealthy’ look of the 16” 8 holes. If you know, you know…. Yadda yadda…
#FilthyStancedonly pic I have is after a road trip where it was filthy:
Thanks Dave! Yep, no prob I will grab those measures for you. Will likely wait a couple days for it to settle out first however.It looks perfect now, Jon! When you get a chance, can you measure the distance from bottom of fender lip to wheel center, at all 4 corners? And note how much fuel was in the tank when measuring?
I fiddled with our 94 E420 to get the height set at 14.25" at all four corners with a full tank of gas. With an empty tank the rear lifts to about 14.75". This is with stock springs, thin pads, and the front springs cut 1/4 coil. I was trying to get it slightly lower while retaining the squishy stock ride. I need to get photos of it clean... only pic I have is after a road trip where it was filthy:
no way! I totally thought it was 744!!!Yup - DIRT color! Hard to tell in that photo but it's 702 Smoke Silver. Purchased with 114kmi in 2013 after our 744 silver one was totaled, the 702 now has 161kmi on it.
