That car TOTALLY needs those!!@a777fan, are you planning to install the little sportline fender tags?![]()
I’ve thought about it, but I still have a few missing parts.That car TOTALLY needs those!!
Yep! No bun warmers here sadly.The interior isn't too crazy of an idea... especially if you don't require heated seats. Front seats will be easier to source than rears. However, it won't be a cheap endeavor. And, it may require getting new leather covers for the donor seats, depending on condition.
Front brakes are not too difficult to obtain, the NLA rear sway is a problem but see if Blue Ridge still has the custom aftermarket rear bars!
That will make it easier, as it opens up more donors from 6-cyl cars.Yep! No bun warmers here sadly.
Check with @jhodg5ck at Blue Ridge for grins, in case the 036 rear bar doesn't come through. I think he has larger (20mm?) available, if still in stock. Dunno pricing though.And someone miiiight have a bead on a rear sway for me. We’ll see.
Yep, rare bird. Didn't @TimL install this in his car recently? Assuming it's similar to 6-cyl models, the difference is quite subtle, making this one of the lowest ROI upgrades IMO. I've always wanted to try it though... and always wondered why MB did not make this box standard equipment on the 036.Also- forgot one item- isn’t there a sportline steering box too?
Have to disagree with you, @gsxr - in my book the steering box ranks as one of the best things I spend money on for this car so far. The steering has much more weight to it and it just feels so tight - very, very nice and would do it again in a heartbeat. It might be though that I'm comparing apples and oranges, as the steering box on my car was approximately 100k miles old before I had it replaced with a NOS sportline box, so some of the difference I feel might be due to new vs. old effect and not due to sportline vs. non sportline.Yep, rare bird. Didn't @TimL install this in his car recently? Assuming it's similar to 6-cyl models, the difference is quite subtle, making this one of the lowest ROI upgrades IMO. I've always wanted to try it though... and always wondered why MB did not make this box standard equipment on the 036.
For sure, Dave. If your travels (fun or work) take you to Seattle, let me know and you take it for a spin. While the steering feels a little more direct, it is the increased heft that has come with the sportline box that I really enjoy.Tim, I wonder how much of the difference is the brand-spanking-new NOS-ness, vs the lower-numerical ratio? Then again, 124 boxes don't typically get sloppy with age (even to 200k, 300k or beyond) so it's unlikely your 100k box had any detectable play.
I've done the Sportline box upgrade on several 6-cylinder cars and while I did like it, the change never had any "wow!" factor. If I was closer I'd love to trade 036's for a short drive up a twisty road to compare!
Looks great.It was nice weather this weekend (who knows how many more of those we’ll have this year), so Üter got a full exterior detail. He’s been looking pretty sad recently. The ‘checking’ of the clear coat seems to be getting worse, and the last mobile “detailer” I had come by last year used some sh*tty product that left streaking on the clearcoat from the beltline down. Only on the drivers side tho. Oddly.
Anyway, wash, clay bar, and a two step polish on the drivers side to get rid of the streaks. Those suckers were on there. Took MULTIPLE passes with the cutting polish to get them out
This was my first attempt with a rotary polisher so I took it pretty easy. Overall I am really really happy with the results. I don’t think he’s ever looked this good. Bright sunlight ‘glamour’ shot.
X-treme close ups!
I ceramic coated after the polish. Also a first for me. We’ll see how it holds up, but since he’s an outside car, I’m looking forward to seeing how he weathers the winter.
Again- very happy with the result. Defo a solid 10 footer now. Couldn’t be happier.
Thx!Looks great.
What are those faint tiger lines below door handle on the front door and continuing on the rear door? Streaks or shadow or water drying… I can’t tell.
Ha!Thx!
Horizontally? Thats the trees from across the street.
Hey terry!@a777fan, Jon, How did you remove the center console with out cracking the wood or finish?
I have to change my mirror joy stick and am afraid of damaging my perfect piece of burl wood paneling.
PS: What’s the little switch between the DS WDW switches for?
A couple of the bolts for the air pump bracket need KoalaGoo™ on the threads. See photo here. If they had no Goo, there will be an oil leak. Remove the bolts and see if they are covered in oil, or if they are dry - that will tell you if they are the source.With the Spark Plug wire tray off, I noticed that there is some oil seepage/stain on the lower part of the block. Anyone have any ideas here? Do the accessory bracket bolts go through the timing covers, and could therefore be a source of a leak?
I've used it 10+ years old without issues, but I was prepared to re-do the job if for some reason the goo didn't cure. Let it cure at least 24 hours, longer if possible, before starting the engine.Outstanding questions for the peanut gallery:
1) I have a tube of the Koala Goo left over from when I had the magnets off last time during my top end re-fresh. I just checked it tonight, and its still viscous. Does it have a shelf life? Or should I be OK to proceed with using it.
Wire brush is all I've used. The old stuff usually comes off very easily, compared to RTV (which you should NEVER use in this application, as it makes the solenoids almost impossible to remove next time).2) The back of the magnets are seriously covered in this Koala crap. Any good tips to speed its removal?
Post a WANTED ad in the classifieds. These can sometimes be obtained from the junkyard, just make sure the post/tab is not broken off. The "door" which locks under the tab and holds the wires in place, is sold separately. These are NLA of course, but if someone isn't already 3D printing them, here's a great opportunity! For some reason the driver side door/clip (119-158-01-73) is more likely to be missing, and rare to locate at the junkyard.Also - Does anyone have a good (unbroken) drivers side spark plug tray/distributor trim available for sale? P/N 119-158-06-85. The little door on mine that keeps the spark plug wires in place has snapped off, as well as the clip that keeps the dress cover snugged down. Ill do a little searching, and then post a wanted ad, but if you got one burning a hole in your pocket. Let me know!
I usually have a set or two of these on hand, I will check my stock. If so will send you a set gratis, as I've done with the @gsxr with a couple of sets over the years.For some reason the driver side door/clip (119-158-01-73) is more likely to be missing, and rare to locate at the junkyard.
Thanks v. much Gerry! Your generosity is un-matched.I usually have a set or two of these on hand, I will check my stock. If so will send you a set gratis, as Ive done with the @gsxr with a couple of sets over the years.
Thanks much for the feedback Dave. You posted the SAI bracket photo that I had lodged in my memory from previous views of your website. I appreciate the reminder.A couple of the bolts for the air pump bracket need KoalaGoo™ on the threads. See photo here. If they had no Goo, there will be an oil leak. Remove the bolts and see if they are covered in oil, or if they are dry - that will tell you if they are the source.
Ive used it 10+ years old without issues, but I was prepared to re-do the job if for some reason the goo didnt cure. Let it cure at least 24 hours, longer if possible, before starting the engine.
Wire brush is all Ive used. The old stuff usually comes off very easily, compared to RTV (which you should NEVER use in this application, as it makes the solenoids almost impossible to remove next time).
Post a WANTED ad in the classifieds. These can sometimes be obtained from the junkyard, just make sure the post/tab is not broken off. The door which locks under the tab and holds the wires in place, is sold separately. These are NLA of course, but if someone isnt already 3D printing them, heres a great opportunity! For some reason the driver side door/clip (119-158-01-73) is more likely to be missing, and rare to locate at the junkyard.
That would be great North! Sending you a PM.As my 420 has moved on to slightly warmer climates I still have lots of stuff I no longer need.
Pair of Beru coil wires, no corrosion, pre-formed (i.e. not floppy), no electrical gremlins…
Yours for the asking.
Best regards.
Thanks terry! I think its only the smog pump bracket that need koala goo. The FSM doesn’t mention anything about it with the WP bolts.@a777fan,
Jon, are any of the water pump bolts penetrating into the oil chases? I’m not sure but gsxr mentioned bolts on the alternator having to be sealed.
A reminder just in case.
lol
@a777fan,
lol
The bolts that require the anaerobic sealant are the three smog pump bolts, the two intake cam solenoids and their bolts, and one of the tandem pump backing plate bolts (6mm Allen bolt). As well as, of course, the front covers of the cylinder heads, and their associated bolts.Thanks terry! I think its only the smog pump bracket that need koala goo. The FSM doesn’t mention anything about it with the WP bolts.![]()
Simple Green Extreme (safe for aluminum) teeth brushes and a Garden hose.what product did you use on the engine degreasing?
Thanks dave!Nice work, Jon! Just curious... what brand were the old caps/rotors, and what brand were the new ones installed? Also, did you add the vent slots to the new caps?
I had slotted the old caps, but did not slot these. Going to see how it does with non-leaky cam solenoids, replacement rotor brackets and all new hardware first.![]()
It needed a little massaging, but it went back together!
Hello Guest !
