OWNER a777fan (E420)
Nice job cleaning the parts and fixing the problem.
You need to stop by HF and get some cheap disposable gloves.
Lol. Yeah. They have been on my amazon list for awhile and i keep forgetting. Thanks for the reminder! Ordering now ...
venom nitrile gloves, one size fits most are the bomb. Lowes has them. Nice clean job, new insulators will be wonderful, cleaned points or new cap/rotor will be golden. Now for the anaerobic sealant...
Nice work! The liquid on the back side of your driver side insulator is the classic case of the hot-misfire problem. Cleaning everything up should keep the problem away for quite a while. If it happens again, try replacing the insulators with new Bosch (<$100/pair aftermarket). The caps & rotors can remain in service for quite a while now that you've cleaned them up, I didn't see any evidence of carbon-tracking or significant wear.
Make sure to use anaerobic sealant on the cam solenoid, btw. Also would be good to let it dry overnight before starting the engine.
:strawberry:
:strawberry:
Thanks guys! I really am surprised those rotors from 1996 are still chugging along. Amazing little piece of engineering there. I can basically expand that statement to cover all the other parts I encountered. There was a nice solid feeling to everything I pulled off the engine. The little details like the plug wire channels really made me smile. So much thought put into everything, rather than just having things flopped about!
I ran across another thread last night that talked about the MB sealant, which I'll have to go back and find. Any recommendations for an aftermarket equivalent? Or is this a spot where MB is best? Oh.. and sealant on the bolts as well? or just the backside of the solenoid?
Any anaerobic should be ok, I believe. OE is 002-989-47-20-10, $33 list, $24 discount. There are some aftermarket equivalents such as Loctite 574, or the Elring version (click here). If the bolt holes go through to the back side, yes, apply sealant to the bolts as well. Photos here:
http://www.w124performance.com/images/M119/cam_solenoid/
:banana2:
Its been dumping like crazy the last few days here in the PNW, and I have had ample opportunity to experience what happens when you combine high horsepower levels, rear wheel drive, and skinny tires. I've mostly had difficulty accelerating away following a turn at an intersection. But this morning on the freeway on ramp I was able to break traction after 'goosing' it at 35-40 mph. :blink: That will get your attention, especially if you haven't yet consumed enough coffee.
Yup. And that is why I like ASR, no matter what the guys in the Matt Farah 500E video said about it. Without ASR, upgrading to limited-slip helps the problem of turning while accelerating from a stop, but would probably make the freeway on-ramp issue even worse.
The easiest fix is to use the stickiest tires possible (with wet traction as high priority since you live in Seattle).
:miserable:
Agree on ASR (All Sensors Replaced). Been comparing my 320 without ASR and my 420 with ASR in similar conditions. As much as ASR is a pain on straight line, it makes a significant difference when taking corners under wet and slippery conditions.
:miserable:
hehe... agree. I'm already on the hunt for a wider OEM rim that will fit without rubbing to increase the width of the tire. The tires on there are only a couple of years old, but aren't the greatest in the wear department. Even more of a reason to get to my suspension refresh sooner rather than later.
Although (on the wider tire subject)... and maybe I am thinking to much about this, but since the overall weight of the car doesn't change... doesn't that mean the contact patch between the tire and the ground will remain the same? The shape of the patch will be different since the tire is wider, but the overall area of the patch should remain the same, no?
:brudda:
Nice Day
Great day for an afternoon fall drive here in the PNW!
attachment.php
More boxes arriving!
Thermostat, oil filter, and plenty of panel clips for the junkyard trim piece I picked up.
oh.. plus the gleit...and the anaerobic sealant for the cam solenoids!
I am going to have to double check EPC... but I feel like I have the wrong thermostat. My car is an April '94 build, which makes me think I need the early PN. I was using EPC when I placed the order though... perhaps one too many after work whiskeys that night :slosh:
yep. I am a ding-dong. Wrong t-stat. derp.
oh.. also notice the new wiper blades and awesome 2phast mirror above!
Is that snow in the background of left window or just reflection? Today's is one of the days where I appreciate the heated leather seats :)
Does anyone know how to interpret this EPC return? I can't tell which PN I need for the selected control arm.
The notes don't give any hints if the 210 number superceeds the 124 number. Its interesting though, when I type the numbers into mboemparts, it comes back and tells me the 124 number 'fits my 1994 e420' while the 210 number does not.
I think the 124-number may be the bolt kit to replace existing bolts, with old / factory links.
The 210-number is the kit needed when replacing the links with the new-style links, which have different bolt hole diameters.
So, it depends if you are replacing any links or not...?
Awesome. Thanks! That would make sense, since the CA part numbers all start with 210!!
:D
Stopped by the dealer today with my title to order a new complete set of keys. The Master and Valet are both still available, but the wallet key is NLA! :(
Just get an extra master key and remove the plastic, boom there’s your wallet key!
oof! is that what they look like underneath?!
:doh:
I'll have an extra master after the new ones show up, so I'll give it a shot!! Thx.
The aerodynamics on this car show a lot of thought and effort. It's literally the only car I have ever driven whose driver and passenger windows as well as the rear view mirrors stay free of water at speed, even in the most blinding rain!
My wet commutes are so much safer thanks to this.
So... the turn signal seems to have become possessed. At times, it doesn’t blink, just stays on all the time. This happens randomly. I assume the relay is starting to go...?
Very likely, yes. It's the combo relay in the compartment behind the fuse box. Pretty common problem. If you have a local Pick-n-pull you could snag a couple of used ones, or get them from eBay, or from captruff / David Hendy. I vaguely recall new ones were a little spendy. I've had to replace this relay on a few different cars.
Thanks much Dave. I assume the relay is the same for all 124s?
I had the same issue and a captruff relay fixed the issue. I have one in my garage...but I can't remember if it's the good one or the bad. I may not have bothered to swap it out before my car went to the wreckers. You're welcome to have it.
A quick update here. Forum friend ‘luckymike’ and I came to an agreement for his 17” monoblocks, and I couldn’t be happier. They need a little bit of love, but will look great on the E420 once I’m able to pick them up from CA!
Many thanks to Mike for a great experience and personal delivery. I hope we’re able to connect when I pick the wheels up, or if he ends up visiting the Puget Sound area.
This has happened a few times on rare occasion, so I thought I would mention it.
I'll pull up to a light after the car is warm (read: lukewarm since I still haven't had a chance to replace the t-stat). Once I have come to a stop the idle speed begins to oscillate, rising and dipping, and acting like its going to stall. Sometimes it has concerned me to the point of throwing it into N, and giving it a little gas. It perks right up and acts normal. Light turns green, I pop it back into drive and take off. Everything is normal. Pull up to the next light, and its fine! Won't happen again for another few driving cycles.
Has the car sat in garage for any lenth of time between runs? Has it been in the fall-winter months only or is this your daily? What is the average miles driven per day?
Codes? Particularly from the E-GAS module?
:cel:
Oooh. Good questions.
The car does not currently habitatate in a garage. (don't shoot). :run: This not my daily, more like an every other daily. I've only owned the car since the beginning of September, so I'm not too certain if its related to the current weather.
I have not scanned for codes. I currently don't have a blinky blinky box. Building one is on the list!!! I did at one point (over a Month ago now) have a Check Engine light on after starting. I shut down and re-started, and the light went away. Is that how the light operates? Turns off, but still might have codes stored? I took the fact that it went off as a sign of a fluke.
Oh.. its a non-ASR car, which means its a TTL/R, right?
It's easier to just buy a blinky box... but I'd recommend shelling out for a 38-pin breakout box, used with a blinky box that has 4mm pins, to make your life easier. Fiddling with 1mm pins down a dark hole with unmarked sockets isn't fun. (Ideally, shelling out for Chinese SDS is the best option but at $500 that's a bit steep if you have no other MB's to use it on.)
Non-ASR does mean T/LLR, correct! Same function thought, for idle speed control. My wild guess at the moment is a vacuum leak somewhere, btw.
CEL generally stays on, but you can check the DM codes (the DM controls the CEL) using the built-in LED & button in front of the CAN box. This only will allow reading/clearing DM codes, nothing else. Check out the stickes in the De-Coding subforum.
:roadrunner:
Post 50 is missing the pictures... I went back to see what you had completed in your 5k deferred MX. So as GSXR (he is real, I know his kids are secretly on instagram) said perhaps a vacuum line is loose or off, and since your issue is hot related, I wonder if you are wet again due to condensation not fully burning off.
Indeed... some of my images went MIA a couple of months ago during some sort of 'update' to the forum software. I haven't yet gone back and added them in...
Indeed. I have yet to start dumping all of the parts I have accumulated into my poor poor outdoor stricken E420. The garage is sadly occupied at the moment with another toy. It sits and waits patiently though... and I only occasionally catch a small tear coming from one of its headlight washers. It must know that one of these days it will be pulled into the garage for the TLC it so rightly deserves.
As you noted in Post 50, I did clean out the insulators of gook a month or two ago. The idle fluctuation this time is completely different, and definitely not the misfiring that was apparent with the wet insulators.
Tuesdays and Thursdays are my 'fun' commute days where I don't have puppy drop off duty, and can drive the E420 to work. Amazingly, today was the first dry day in as long as I can remember. As such, I was able to get into the kickdown switch on the on ramp. When this thing finds first... watch out. Still exciting and surprising after owning for several months!
:124fast:
Side question... where would be best for an alignment? I have an indy shop here in Seattle I like to use, but I have seen that most here still prefer the Dealership for this sort of thing. Is that correct?
Dealer is preferred. Is Steve Geyer available? I'd at least ask if he does that sort of thing these days.
Indy shop is OK if they align a LOT of Mercedes... and either have the spreader bar to set pressed toe, or know how to properly compensate for it. Almost anywhere else, they'll get the toe screwed up.
Stealership is preferred, particularly if you can get a special/coupon deal to lessen the ouch. Expect to pay $175-225
ah! righto... I'll have to reach out to him. Thanks for the reminder!
Well that was easy. Steve will be mounting some new tires and doing a 4 wheel alignment at Lynnwood MB next Thursday.
Went with Michelin Premier A/S. Supposedly have great wet traction capabilities!
no :burnout:
I need a bit of help. Trying to install a vent tube for the battery in the trunk. I’m not entirely clear how its supposed to be routed. There is the rubber drain plug under the battery, but the one hole in the battery tray that I thought would accept the tube is completely covered when the battery is installed.
You can see what I think is the drain hole (rubber plug removed) and the hole in the tray frame that looks like its meant for the vent tube.
Hmmmm... That looks a little different from the 500E battery area.
The following is a picture of the 500E battery area without the tray installed. What I did was use the REAR hole for the vent tube. The vent tube in my car goes from the rear of the battery, then goes under the battery tray and into the hole shown below the sheet metal. The tube does not go THROUGH the battery tray .... it goes AROUND the battery tray and then under. (at least that's how I did it in my 124.036)
Who has viewed this thread (Total: 10) View details
