Exactly this - use the hex slots on down the samshafts to hold them not that front one.That is just a thin wrench for rotating the cams. Anything that will rotate them without damaging the lobes should be fine.
It's a 30 mm wrench, correct?That is just a thin wrench for rotating the cams. Anything that will rotate them without damaging the lobes should be fine.
Well, I'm following Gerry's detailed write up with pictures. He removes intake sprocket to replace the located in the upper V chain guide, and it seems easy-enough - with a proper tool to help with reassembly. And a dilettante like me needs pictures and detailsExactly this - use the hex slots on down the samshafts to hold them not that front one.
Also, I would not be taking the intake adjusters apart not sure why it is sometimes suggested but it requires special tooling etc and no need. Pull the camshaft(s) complete or unbolt the exhaust camshaft sprocket.
That's my plan, following Gerry's write up. Maybe Joe's approach is easier, but for an unversed tenderfoot such as myself, lots of details + pictures is confidence-proppingGot it. To replace that rail, you either disassemble the cam adjuster and leave the cam in place, OR remove the cam+adjuster together. When I did the job, I went with the first option as Gerry did, leaving the cam in place and disassembling the adjuster. Not sure if the second option is quicker or easier. (??)
The M104 injectors are totally different than the M119 LH units.I got my pintle caps from Master Injector in UK Gerry, I believe they make them directly and the fitment was exact same as OEM IIRC but will check in future as I have a M104 set to do this weekend actually!
Yes I order the sets each time to suit the application. So for my m104 for example I emailed them asking for a kit of 6no sets and provided the Injector part numbers from the injectors in the carThe M104 injectors are totally different than the M119 LH units.
Is there a typo here? Exhaust cam sprockets and a chain tensioner MUST be removed to replace the uppermost chain guides?Replacement of the two uppermost chain rails (one on each side) can easily be done after the valve covers and front cylinder head covers are removed; the exhaust cam sprockets removed; the timing chain tensioner and top timing chain guides removed; and the intake cam adjuster mechanisms removed.
Dave thanks! I was under the light confusion that only intake sprocket and the between-the-sprockets guide needs to come out to access the uppermost V guide. Do you recall what needs to be cleared out of the way to extract chain tensioner (my car is a 93 400E)? Specifically radiator, fan clutch? ThanksYou need to remove the intake cam sprocket (adjuster mechanism) to access the upper/inner guide rails.
To remove those, you need to remove the chain tensioner and remove the passenger exhaust cam sprocket, which allows enough slack in the chain to then remove the intake bits. And, I believe you need to remove the driver side exhaust sprocket to replace the 1 rail which resides below it.
It's not as hard as it sounds, just very time consuming, particularly if you are cleaning everything while it's apart.
View attachment 148134 View attachment 148135 View attachment 148136
Yeah, only the intakes need to come out to access those guide rails, but you have to pull the exhaust sprocket first in order to get the intakes out. A and B must come out before you can access C, but you can't skip A.Dave thanks! I was under the light confusion that only intake sprocket and the between-the-sprockets guide needs to come out to access the uppermost V guide. Do you recall what needs to be cleared out of the way to extract chain tensioner (my car is a 93 400E)? Specifically radiator, fan clutch? Thanks
IIRC the job would be miserable (or impossible with the fan clutch in place; remove the fan+clutch assembly. Radiator can stay in the car if you aren't doing the full Monty with front crank seal replacement. Note in the photos above, the radiator is in place.
It's now an NLA partIt's the black larger-diameter Tecalan tubing. MB part number 000 987 27 27. You need 1600mm of this tubing. It should be ordered by the meter from MB, so you'll have to get 2 meters.
Ugh. At least this is available aftermarket, however contact the vendor before buying to confirm you won't receive multiple 1-meter lengths instead of a continuous length.[Black 8mm OD pipe 000-987-27-27] now an NLA part
Not that I can think of, although many of the Mercedes-Benz zip ties are thicker and more robust/wider than aftermarket ones.Are there any distinguishing features to Mercs zip ties vs mundane ones?
Mate, were you able to find it elsewhere?Hi Gents. Is there a replacement for 119-158-06-85 perhaps? It seems to be NLA. The other side 05-85 is still available. Thanks.
Gerry, do you remember how you jiggled the scoop out after removing the 4 bolts that hold it? Its long lip that is under the front bumper... Does it come out first or last?
Yes! I gave up after 15 minutes of wrestling with it. Afraid to break it too, as I'm sure it's NLA. Hoping its removal is still fresh in Gerry's mind so he share how he managed to extract it intact.I recall that stupid scoop being stupid hard to stupid remove. Grrrrr. Might require some bending around, IIRC.
No! But I did not look very hard.Mate, were you able to find it elsewhere?
Actually, I'm going to correct you here) A little after I posted my question, I saw in your "light top-end" thread, in one of the posts there containing pictures of myriad parts, cross checked against your Picasso spread sheet - that you have found the NLA part somewhere!))No! But I did not look very hard.
As I remember it, I wiggled out the TOP of the bucket first, then angled it forward and then eased out the bottom past the chrome strip. Just take your time and work it, and don't force anything.Gerry, do you remember how you jiggled the scoop out after removing the 4 bolts that hold it? Its long lip that is under the front bumper... Does it come out first or last?
Then it's time to remove the water pump itself. There are six 13mm bolts that hold the water pump to the front timing cover. Pay attention to where each bolt goes, because there are several lengths of water pump bolts. I also removed the four bolts that held the alternator support carrier to the front timing cover. Loosening the lower alternator bolt allowed the removal of this alternator support carrier.
@gerryvz, the above is the sequence in which you removed Air Pump. Does the water pump have come off to extract the Smog Pump? What's the minimally invasive way to get the Air Pump out? Thanks
Thanks! Good to know that water pump removal is not imperative for extracting air pump.but you shouldn't need to touch the alternator or water pump.
Thank you! That's exactly what I wanted to confirmThe smog pump is located on the upper/middle front passenger side of the engine. The water pump is located on the middle/front center of the engine. Completely different locations, and completely different attachments, and no inter-dependency on either to be removed.
thanks! I found it. It was between windshield fluid tank and the coolant tank. hidden underneath other cables. once i dug in there I've spotted the 2-prong connectorIf I remember correctly, it is a simple two or three prong plug that exits behind or underneath the passenger side headlight/bucket. You will have to follow it. I believe it is documented in my HOW-TO if you read through. Yes, I did remove the pump entirely.
noted, thanks! the hoses are rock solid indeed. where one of the hoses attaches to the engine, it broke off (easily), leaving a piece on the neck of the engine connection. I used a long screw driver and tapped it with a rubber mallet to split hose leftover for an easy removalOnce you have it disconnected, DO NOT put it back under the Zip-tie. Next time it will be much easier to disconnect.
That worked very well! Knowing that the TOP of the bucket extracts first, it took me all of 30 seconds to extract it. It feels that the bucket will break in the process, but it appears sturdier and flexible enough. That cringey feeling though one gets inside while bending/prying 30 year old NLA Merc plastic part))As I remember it, I wiggled out the TOP of the bucket first, then angled it forward and then eased out the bottom past the chrome strip. Just take your time and work it, and don't force anything.
Hello Gerry,I had I think three pintle caps that fell into the intake when I pulled out the injectors. They got sucked up readily with the first pass of the shop vac. After a first pass at full suction (with no attachment or modification), I put a 3/8" ID tube onto the end of the shop vac last night and was able to get a lot more stuff up, and ended up (just on a few valves) with even more stuff out using Q-tips soaked in solvent.
Based on the limited work I've done to fix this, I have no doubt that I can get 98% of the dust out of the intake and off of the intake valves. Big picture, as I said, I'm not worried -- it's just going to take an hour or two of careful, methodical work to get things cleaned up.
I tried to look down but can’t see anything… I know for sure that two caps are there but I don’t know about the other ones…I'd avoid starting the engine if possible. Can you use a flashlight to look down each bore and see if the other plastic caps are visible?
If the caps did get spit out the exhaust, they would melt against the catalyst honeycomb, which probably is not a good thing...
I am really not sure. Plastic is soft and shouldn't hurt big metal things, but it's difficult to predict what might happen after they enter the combustion chamber. You can use a borescope/endoscope through the spark plug hole to view if anything is in the cylinder but that won't help extract it.Right now I have my 500E cat less so them melting would not be a concern. But wouldn’t them damage the pistons or valves?
I'm not a Gerry nor do I play one on TV, but these sensors are installed dry, with a new seal ring if available.Gerry, Do you recall using any sealant on these three intake manifold water temp sensors or do they just go in dry?
Jon, this is yet another EPC error I need to add to my list.Thanks Dave. I ordered the three sensors based on the helpful @gerryvz parts list, supra. Any idea why the EPC shades out the 2-pole sensor and doesnt list the part number? I ordered the one-pole and two-pole sensors from the dealer but they havent arrived yet.
