Took care of a few minor things today after work:
Got the front of the car up on ramps and had a really serious going-over of the bottom of the engine compartment and transmission area. No surprises, thankfully. I was a little disappointed to see that the time the car spent in the Midwest did take it's toll on the heat shields around the crossover pipes. There are a number of areas where there is perforation of the shield from rust through. The pipes themselves are good, but the heat shield is rough in spots. Oh, well.
Power steering pump reservoir hose is probably leaking. Return and pressure lines both look good, thank goodness. They're both pigs to replace as many of us know. In fact, from what I could see of the return hose it appears to have been replaced at some point in time as the rubber and clamps on it look quite new.
Got a new Stabilus steering damper, as it the one on the car appears to be the original. I'm pretty sure it was after taking it off:
Not only was it leaking, it had the resistance of a wet noodle. Yeah, I called that one. Looking forward to driving the car with the new damper, I'm sure it will make a difference.
Idler arm bushings looked good, and I was pleased to see all the little heat shields around the tie rod ends were still in place. While I was poking around I saw this sitting on the left side engine mount:
Looks like the end of my former "go tubes" that was patched with a Solo cup. The piece must have come off the end of the tube when someone removed it and fell down into the engine compartment. I wonder how long it was there...
Cleared out the evaporator drains, which had a boatload of detritus in them for some reason. I don't think I've ever seen that before. Weird.
Noticed that the bushings on the ends of the sway bar were pretty sloppy. I guess I'll get a complete set of new bushings, drop the bar and replace them all at once. While I was there I applied a liberal amount of Kroil to all of the fasteners in anticipation of the job.
Had to give the oil drain plug another bump. Still dripping ever so slightly. I'm going to win this battle, I don't want to put that aftermarket plug back on the car.
Lastly, as I was closing up the trunk, I pulled the tool kit out of the spare tire bucket. It seems that at some point someone got what appears to be a W140 tool kit and put it under the cover where the spare tire bucket opens up. Of course it doesn't fit and makes a large hump in the trunk carpet, so I took it out. What's weird is that the bottom "tray" that the foam piece holding the tools fits in is nothing like any W140 tool kit I've seen. I tinkered with things for a minute or two, and its clear that this tray would never fit in the spare tire bucket under the circular access door in the spare tire cover.
I'll post pictures here so people (Gerry?) can try and identify where this tool kit came from. It's nearly complete, and even has a tow hook, which I've rarely seen. I'm pretty sure I've got the missing wrenches for it in my parts stash, too. If it does fit this car I'm not sure how.
Tomorrow a major road test! I have an appointment to get my title, registration and plates tomorrow morning, so the car will get a good shakedown on both city streets and highway and I'll have a chance to top off the tank with some TopTier fuel at Costco. Fun!
) the clutch started engage!! Woo-hoo! When I pulled into the driveway and dropped to idle it did slip/screech again for a moment, so it's not completely burnished.
Certainly Ms. Marie Kondo would not approve.....
