Multiple updates tonight!
Replaced the leaking cam seal. And I only destroyed two of them before I got it right.
Definitely leaking pretty badly, as I had this area cleaned up after I found the issue this weekend.
Was able to get the seal seated in from the cover face by about 2.25 mm all around.
I used this Volkswagen cam seal i had lying around from my Passat days. Worked out pretty well!
The old seal after extraction
Time will tell if I fixed it correctly, but so far no apparent leaks.
Next i changed the oil. The old stuff only had about 1500 miles on it, but I wanted it outta there since I had everything opened up. This also gave me the opportunity to drop the oil pan!
The pump pickup tube was the old short style.
As a bonus it was cracked and all dangly
I replaced it and the pickup screen with new.
Some numb-nuts had used RTV on the pan side of the gasket. It took a dremel wire wheel and about 45 minutes to clean all the junk off. Re-installed with a new gasket and no RTV.
Final piece. I confirmed the aux fans were non-functional on low speed by jumping the ac pressure switch connections. I could hear the relay click... pulled it and found this!
Aux fans are once again functional at low speed!!!
Dave pointed me to a klink post which discussed upping the amperage on that fuse slightly to avoid future blows. I have to do some additional research in that thread before committing to that.
